My car is equipped with wireless charging but it does not seem to work with my Xperia Xz3. Is there anything I need to do to make it work.
Hi @Rufus1, welcome to our forum!
As @uliwooly mentioned, the wireless charger needs to be Qi-certified as this is the cross-industry electromagnetic induction standard.
If you are not sure if this is the case, you should be able to contact the car manufacturer and they should be able to provide you this information. If you are using a case on the device, you can try removing this and see if it starts to charge.
Let us know how it goes!
