Xperia XZ restarts continuously
víctor89
My xperia xz just Restart every minute, turn on and turn off, as soon as possible the xperia logo show up at the screen, some can help me??
I took out the sim card and micro SD and anything happened, is the same problem
2 REPLIES 2
profile.country.US.title
Qatrium
@víctor89
If your phone is stuck in a boot loop, then I'd suggest that you perform a software repair using Xperia Companion. This will do a clean installation of the latest firmware and will also wipe your internal memory, meaning you'll lose all data on your phone (not SD card).
You need your phone turned off and charged to perform this process. To force your phone to shut down, press and hold the power and volume up buttons together for 10 sec.
Follow the steps given in the blue link, and keep us updated.
MIA_81
It's a long shot, but this happened to me as well on two separate Android devices as well, one HTC and one Xperia Z1. I solved it by uninstalling the Facebook app (not the Messenger one). If you cannot uninstalling it (i.e. it was bundled from the factory), try disabling it, it's worth a shot than by doing a reset and re-installing and re-configuring all the services.
