Xperia xz1 reboots continuously while charging
RAFAELerhs
I have a problem with my xperia xz1, what happened was that i immersed the cell phone a few hours ago and when i tried to charge it ,it stopped charging after some minutes and then it rebooted continuously, i unplugged it and i noticed there was still water in the port, i already blew the water but it keeps doing the same, i guess theres still moisture in it but i dont know, has anyone had the same problem?
Tags (3)
Uliwooly
@RAFAELerhs
I'm sorry to hear that, it'll be wise to remove the SIM and SD card > place the phone in a container with rice for few hours
3 REPLIES 3
Uliwooly
@RAFAELerhs
RAFAELerhs
That was the solution, now it works perfectly, thanks!
Uliwooly
Anytime
