XZ Touchscreen Lag & unresponsive when charging
Third
I recently used a Samsung Fastcharger and anker usb charger with an adapter attached to fit the Type C port that the XZ has.
I've noticed that when the charger is inserted the touchscreen lags and often misses my touches by doing actions which I have not told it to do.
It works perfectly after I remove the charger.
2 REPLIES 2
Uliwooly
@Third
Does this happen with all cables or just with the adaptor?
Dark2kraD
Mine too.. and it is happen when i'm using the Samsung charger (it's said "Fast Charging Supported").
When i'm using the Sony charger, the lag is gone.
