xz1 bluetooth
bod2
xz1 bluetooth
hi,,,have had xperias z1,,,, z5 compact & now have the xz1 compact,,, however the xz1 compact keeps droppiing my parrot bluetooth connection in the car despite upgrading to oreo (8),,,, any help appreciated,,, replies to me,, many thanks ian
ovesund
Well, actually XZ1 shipped with Android 8.0 (Oreo) out of the box so the only upgrade you can have performed was the monthly security update.
Anyway, like the previous post suggested, Oreo is terrible with Bluetooth. Some devices work but some just don't work at all (like all modern BMW cars) without going into developer options and change settings. Then you get something that kind of works but not at all as good as with Nougat.
I have good hopes that most of the problems will disappear when Sony pushes out Android 8.1 to XZ1 and XZ1C. I don't think we will see it until sometime next year though since it was released just yesterday by Google.
10 REPLIES 10
radosuaf1
In case of Oreo it's not "despite" but rather "because of".
bod2
actually it was doing it b4 the upgrade so don't think it was due to upgrade
ovesund
bod2
Thanks for your reply, guessed it was something to do with that
Focusyoufaq
Go to settings>apps click on tge three dots in the top right select show system apps look for Bluetooth swlect saved storage> clear cache your problem should be fixed now it worked for me
Mariusz002
Hi i have also Bluetooth problem with xz1 when phone using WiFi network and using Bluetooth head set plantronic voyager 5200 my headset is disconnecting sometimes and connecting again it's annoying because it does this things when I'm on the call with someone  anyone had the same issue maybe  if I turn WiFi off all working grand
Tags (1)
Damo_
Contributor
Have you tried changing the Bluetooth AVCRP version to 1.4? To do this:
  1. Unpair both devices from each other.
  2. Go to Settings -> System -> About phone -> tap multiple times on "Build number" until you enable "Developer options"
  3. Go back to Settings -> System -> Developer options -> Networking -> Bluetooth AVRCP Version -> Choose AVRCP  1.4
  4. Restart your phone
  5. Pair devices and test
Worth a shot!
Mariusz002
Hi thanks for help yea I was trying that option in developers settings. Also I was doing software repair by Sony companion and factory reset even was using phone in safe mode without any app but still the same issue
sebarave
When my headphones are connected via bt and I'm using WiFi at the same time only to stream music from Spotify even if I'm close to phone sometimes I hear some brakes and even sometimes bt connection is lost so Spotify pause. The same situation when I connect Xz1 with my music system at home. This is strange. I had Z1 compact and there was no such problem.. those breaks are so annoying! There is no such problem using internet from mobile. Also when I try wire headphones even with WiFi also there is no such issue! Why oh why ;(
