when starting up my phone it says to go to specs and info all the time and showing the phone features
and draining the battery
thanks plumbcrazy
Hi @plumbcrazy ;
Try restarting the phone in safe mode to see if some third-party app is causing it.
hi nunosen2
i've tried that it seems to be a prototype phone meant for shop use only
thanks plumbcrazy
Hi again @plumbcrazy ;
Try disable demo mode typing in the phone app keypad *#*#73556673#*#*.
hi nunosen2
i've tried that says this device for store mode only, can't be disabled
thanks plumbcrazy
Hi nunosen2
Same thing again this device for store mode only, can't be disabled
Thanks plumbcrazyr
If you can not return it and want to use it then try flashing same version but stock firmware. Search for the information in XDA. If you did not understand what I said and you are not technical person then forget it - it is easy to ruin your phone if you don't know what you are doing. Anyways. Good luck with the phone!
