Bonjour avait vous trouvé une solution pour protéger l'écran de votre xperia xz3 convenablement ? Dur de trouvé un produit adéquate avec les bords incurvé.
Hello had you found a solution to protect the screen of your xperia xz3 suitably? Hard to find a suitable product with curved edges. - GT
Maybe on this page?
It's AliExpress, set your language to French for translating.
When you buy it now it will arrive around half till end September.
Check out SG Fresh idea. I recently purchased a tempered glass protector from them. It's fantastic. I've also read of people buying Loca TP-2500 glue and a glass protector from Amazon, because most of the glass protectors available aren't full adhesive.
