Xz3 speaker breaks
玉成
Xz3 speaker breaks
我的xz3喇叭來電鈴聲有時會破音,是軟體問題嗎
My xz3 speaker ringtone sometimes breaks, is it a software problem? - GT
6 REPLIES 6
Veselin1
I have the same issue. When I have an incoming call, the ringtone breaks and the sound is terrible. It also happens on some apps when they have background music - "Star Walk 2" for example. It is so terrible that I feel embarrassed. Please do investigate and fix it. I am starting to hate my phone because of this. Frowning_Face
profile.country.NL.title
Strampke
There are others reporting this kind of issues.
It's interesting to know if it is a software or a hardware problem.
You might try some tests in the Support app or better a software repair with Xperia Companion.
See how your device behaves afterwards.
Please submit your comments after you tried.
KiraDuo
My xz3 also appear that problems.
I need to take my cellphone to sony ?
Strampke
How is it behaving in safe mode?
In safe mode just the perinatale apps are starting up and interference from self installed apps is eliminated.
If behaviour in safe mode isn't good as well then take up contact with support.
Safe mode and support can be found easily in the support app on your device.
Ajuklelegendar1
Same problem on xperia xz3 but very rare. This is only on yotube. (my experience)
mcvisster
My wife add me have xperia xz3 and also facing the same problem. Did repair with pc companion and problem is still here. Dont know what to do. I think its a bug. Also there is on "crackling sound xperia xz3 forum" issue. Sony response and fix issue.
