XZP dualshock 4 lag solution
Andyyy
1. Connect bt headphones
2. Connect ds4
3. Turn off bt headphones (not from xperia, Just turn off headphones)
Works with xb70bt, m504 So i thint Will work with all audio bt devices.HF.
4 REPLIES 4
Ausar
2. Connect ds4
Work great from me... Tks for your sharing
Marioss
Today i try it and it works really great with your tutorial (better than bt apps from play store).
If someone from sony read it now : will be this problem fixed in future? Thx for any answer
todo1156
Sony has solved this problem on previously version.
At least my XZP is no longer delayed
Marioss
Please, can you tell me which version? Now i have 47.2.A.10. 45 (dual) and problem is still here. Thx
