I would have asked this question when I was using xperia Neo.
But I need it badly now.
The way I add audio music to zl is copy the album folders to internal/ sd card. Once copied opend walk man and start lestening.
What I am missing in walkman app is, If I browse as albums, each folder is not appearing as one album rather songs are getting divided based on other logic.
2nd is I cannot start playing folder after folder (each folder is an album)
I tried media sync app in pc companion, there also I faced similar issues.
Can anybody help me how can I play music each folder one after other ? I there other way to copy music to phone?
Your problem is that perhaps you need to double check the album details before you transfer the folders, on your PC > music > select an album > view details > are all the songs under the same album name? if not that's the problem
PC you mean PC Companion? I will check that.
Uisng PCC is only way to this?
Is there a way to play as folder if I copy them without using PCC?
Because PCC takes longer time to copy files than copying files directly to sd card.
no, I meant your PC/computer.
Thanks Uliwooly.
That worked well for me. But Most of my music folder's doesn't have Album info. I had to do it for most of the folder and recopied to phone.
Now the % of album show up in walkman is more accurate.
