Always asks for permissions
Bassem_baz
I have sony xperia Z3  dual and I update the system to 6.0.1 marshmallow  and  I can not change the cover  photo of facebook or instagram after that or even send any voice message on WhatsApp   the mobile asks for permission always and when I follow the steps to change it nothing changed and the problem not solved.
2 REPLIES 2
ChloeS
Contributor
Hi @Bassem_baz,
Welcome to the community!
Sorry to hear you're having issues, since having these problems have you attempted to uninstall and then reinstall these applications?
First use would again prompt you to allow permissions for the app, can you see after a reinstall if allowing the permissions will work?
Let me know Slightly_smiling_Face
display-overlay
to support
i have the same problem. if i reinstall all my app all the time. is not make sens for us this phone.
did u have a better soultion on my z3 phone.
firstime i have this problem with sony.
wish
mr mak
