Android wear problem after update
brian_of_zero_o
Hi, After updating my phone (z5p) to Android 7.1.1 with the flash of the phone, it gets hot and when playing the video, it also slips the program section in the scroll lag, as well as the program phone phone battery and empty and like Do not hold it up. Will there be an update to fix these issues or that Android 8 will be released for z5premium?
3 REPLIES 3
Uliwooly
brian_of_zero_o
 Thanks for the reply. I do not have a malicious program on the phone that caused these problems.
brian_of_zero_o
  1. Hi. Dear Android 7.1.1, Unfortunately, there are some problems that need to be solved and not. Example: The ringer does not work. The notification light does not work. The unit is difficult to playback in MP videos. High and low speakers are not sound. The higher the speakerphone is, the volume is low when the phone is ringing.
  2. All programs are upgrades.
    I hope I've been able to conceive.
    Sony will give you an update to fix all the bugs and problems Android 7.1.1 for the z5 family.
