I have CPU usage with code 8.02/9.05/8.80 and com.android.systemui displayed in the top right hand side corner of my Sony Xperia Z5 ver7.0..
Is this CPU overlay??
And how to remove this code display??
Please help!!
Hi @DraXZ5, welcome to our forum!
It does sound like you have enable the setting called "Show CPU usage" in the developer options on your phone.
You can remove this if you go to Settings > Developer options > scroll down and find "CPU usage" > turn it off.
Let me know if that helps!
In my setting I have no developer options, on the Sony Xperia Z5, unless I'm missing by something?
Hi again!
Developer options should be available just above "About phone" at the bottom of the Settings menu.
If you can't find this it here, tap on About phone > tap on "Version" 7 times until you are a developer, go back to Settings and see if you are able to see "Developer options" now!
If you can, tap on it and then scroll down and find "CPU Usage" and turn this off!
