drop down notification not working during lock screen
amelianoble
Hello, I just switched over from the iPhone and I wasn't sure if there was a trick to it. But when I'm in the lock screen and I swipe down nothing happens. My drop down notifications won't work. Is this normal on a Sony phone? I'm using a c6906. Android 4.2.2 and the build number is 14.1.g.2.257
Does that make a difference or am I missing the trick to do it?
Mystic
silly question but what lock screen are you using? Maybe it has to do with a more secure lock screen than the simple swipe... my assumption is that if youre using a pincode, it wont let you swipe down notifications since youve opted for a more secure form of security.
Yes ive tested it. if youre using a pin or a pattern it wont let you show the notification pannel Grinning_Face Great security imho Face_with_stuck-out_Tongue_&_winking_Eye i anyway dont bother with key locks.. if anyone wants to get at your phone they will.. simple as.. its a deterent sure.. but most folks that bother with phone theft know how to get around it...
Hope this solves the issue.
5 REPLIES 5
Mystic
on the lock screen make sure your finger touches the top notification bar when you pull down. dont let it touch the widget area else it will just expand the existing widgit...
Try it once this way it should solve your issue...
amelianoble
Yeah that's what I've been doing. The widget isn't expanding or anything. Nothing happens when I try to pull it down =\
Mystic
amelianoble
Thanks I was using the pattern and tried the swipe and it worked! I guess it was a security issue or something.
Mystic
Well if you set a patter or a code youre naturally worried about the data on the phone.. so they naturally wouldnt let anyone just access your drop down now would they Winking_Face I think its good that they do it that way...
