Fast Charging Problem?
ytheekshana
Hi. My device is Xperia Z5 Premium E6853 7.0 (32.3.A.2.33)...
Recently my device takes about 3 hours to full charger using the original charger......
But I used to charge my device full within 1.30hours.
How to check if the device is using fast charging or not?
Is there a way to see fast charging enabled.....?
1 REPLY 1
XDevNima
Hi
When your device is not charging fast enough at the end of the lock screen during charging you can see " slow charging" text.If not it means your charging speed is good.
For fast charging you must use Qualcomm Quick Charge 2.0 chargers.
From sony you should have UCH10 charger. Also UCH12 is another fast charger from sony that supports Q Quick Charge 2 and 3 and MediaTek pump express + 2.0.
Good luck
