freeez
Hamolina
freeez
i was using my xperia that suddenly it froze and i could not do any thing's
so i tried to turn it off and on in order to solve problem
but when it turned off,i could not turn it on again
what i am supposed to do?
Uliwooly
press and hold power & volume up for 10 seconds
if that doesn't work
press the red button under the SIM cover
4 REPLIES 4
Uliwooly
Hamolina
it worked,thanks a lot
but can you explain for me that what happened to my xperia?
Hampus
Champion
Probably there was a process or similar that hanged which a cause this behaviour. You can use this key combination to force a shutdown of your phone.
Uliwooly
Anytime
