functions and overheating
Erick45667
my phone is overheating fast
3 REPLIES 3
Emil
Enthusiast
Hi @Erick45667,
I'm sorry to hear this. Slightly_frowning_Face
Is it when you do anything particular this happens, or does it happen regardless what you are doing with your device? I recommend that you reboot your device to safe mode to see if this behavior is caused by one of your downloaded apps as these will be temporarily disabled in this mode.
Also make sure your apps and Android system is updated to the latest available versions. To update your Android system,  go to: Settings > About phone > Software update. You can update your apps if you go to: Google Play Store > Tap the 3 lines in the left corner > My apps & games > Update all.
Let me know how it goes. Slightly_smiling_Face
Erick45667
the problem persists regardless of the recommended changes
Emil
Enthusiast
If you are still experiencing the same thing after trying the troubleshooting I suggested earlier, I recommend that you perform a software repair using Xperia Companion.
Keep me posted on how it goes. Slightly_smiling_Face
