how to change keyboard
chaotics
i had some system update today and now i have no option to change my keyboard anymore.
i got to language and input settings and it just shows me spell checker and personalisation. i can click on "on screen keyboard" and select one of my installed keyboards but then it just takes me to its settings. i can't actually select to use it.
i also can't do this with the settings icon while trying to type text, that also takes me to personalisation settings like "skin" or "height".
1 REPLY 1
Jake-SonyXperia
Champion
Hi @chaotics,
Welcome to the community,
Let's see if we can help resolve this for you.
Try the following.
Apps > Settings > Language & Input > On screen Keyboards > Press Manage Keyboards > Turn off the keyboards you do not wish to use > turn on the one you do wish to use.
This should resolve the problem.
I hope this helps.
