My Z5 compact dropt to the floor and now the screen is broken.
The pfone does turn on and the screen is visable but the touchscreen does not work.
I use an OTG cable to enter the phone.
The problem is that I was used to enter the phone with a swipe patern while the I now only get the option to enter a PIN code.
I never used a PIN code to unlock this phone.
Is there a way to translate the swipe pattern to a PIN code?
If not, is there an other way to unlock the phone without loosing all the data?
Thanks for your help!!
