Auto focus of xperia z if working only wen i tap my phone slowly on its camera side..any idea what is wrong?
As uliwooly says, in low light conditions or with moving objects the camera might have a hard time focusing but you should not have to tap on the back of the phone. If the camera doesn't focus unless you tap on the back of the phone i recommend that you contact a service location or your local Sony Xperia support (http://www.sonymobile.com/global-en/support/contact-us/) for assistance.
if its in low light conditions its normal.
Ya i have given to the service center and they are replacing it with a new phone.. its a hardware issue. thank you for ur support..
Did the repair your phone of give you a new one?? Mine is doing the same thing.
