Is it possible that LG has a better picture of the Z1??? today I looked online and it is, as Sony can I let the phone with 20 megapixels, has a worse image than lg
Can't be sure that Xperia Z1 image was that really bad cause recently alot user is facing Yellow Hue Tint problem that causing the display color and the image looks not nature and not accurate....it should not happen since it got the latest Sony BRAVIA technologies optimised for mobile and Triluminos..
so after this problem solved then let's see the Xperia Z1 image good or not
Have you checked this
http://www.gsmarena.com/piccmp.php3?idType=1&idPhone1=5596&idPhone2=5543
here is the link where the images were compared
I know of that post. My advice to you would be to ignore most of what neilmc1983 over at XDA has to say because he has some kind of biased agenda to make the XperiaZ1 look bad. He was also called out by several people for tampering with those images to make the Z1 look bad. And furthermore several people pulled up the same pictures that he claimed were bad and found out that they look just fine on their own phones.
neilmc1983 also was called out for being a nut case because he's been spending the last month doing nothing but making bogus and extremely exagerated complaints about the display and camera. Yes the Camera software needs some improvement. But neilmc1983 is a lunatic with a bad case of OCD, I wouldn't pay any attention to the weirdo.
Did not think so pleased when painting the face, do not look very realistic, or wrong color, or not very clear in some areas, being blurred, because I think that the pictures that are posted are correct, a lot of people complain about the camera
We paid phones around 800e and did not get what sony reklamirao.lice the pictures looks like a plastic made photo shop
Well, here are some I made recently. I am not super happy with this cam, but you can definitely work with it. It takes terrible photos when the lighting is bad and the mode is auto, but with manual it gets much better.
1st image is auto, 2nd manual.
I am happy with the phone but when shooting with strong noise. to be heard
This one is fake:
+ take into account that zoom on Z1 is bigger
I own Z1 and pictures are way better, video recording needs update because lags.
