BLAST.......alexdon beat me to it....AGAIN HA HA!!!!!!!
Hahahaha,don't worry my friend,it is good to have people eagerly waiting to help.
Note to self....'MUST TYPE FASTER' :smileysmileywink:
You can't beat the grey wizard
You cannot have swipe to unlock together with PIN/password/pattern.You can have only one of those.
I don't trust 3rd party security apps. But thanks for the help on that!
Are you sure.....it def does on my Z2 & others i have looked at.....SECURITY.....tap on SCREEN LOCK....enter whatever you are using at the moment, pin/swipe etc......it then takes you back to SELECT SCREEN LOCK which has 6 options ranging from NONE down to PASSWORD....
He wants swipe and after that to have PIN/password.
Ah i see.....sorry about that
