Blocked EXPIRE Z tried to change the sim card. He had not seen the new (although the sim inserted in the phone screen and saw it) I tried to change the settings. but in the "mobile data" lost count "Service Provider." as soon as the village tried to charge the battery .. but even after 12 hours of charging, he never joined. tried
run through the program via USB
Update_Service_Setup-2.11.12.5.exe
Sony PC Companion_2.10.173_Web.exe
Update_Service_Setup-2.13.10.201308300830.exe
and there are no results. it tries they
Да сим-карту перестал видеть .. я взял новую микро -сим. но её он тоже не видел . и в настройках пропала графа " апператора сети " пытался изменить настройки сам . но села батарея . теперь немогу его включить .
даже через USB его не видно на компьютере .
Let me see if I understand the problem, the problem is that your Xperia Z does not recognize your SIM card? if so, get a brand new MICRO SIM card.
I don't speak Russian, use
translate.google.com
@ullis227 wrote:Yes sim card stopped to see .. I took a new micro-sim. but it also did not see it. and disappeared in the settings column "apperatora network" was trying to change the settings yourself. but it's battery. now can `t turn it on.
even through its USB is not visible on the computer.
Connect your phone to the wall charger > press and hold power & volume up for 5 seconds > let the phone charge for 1 hour > after 1 hour try to repair it SUS
