Mobile camera is not working
Hi @Alias380,
Welcome to the community!
Sorry to hear you're having problems with your camera. Can you please clarify the problem you are having with your camera? Are you receiving an error message when you try to use it, if so what is the error.
Please let me know
Hello, after the update on Android 7 the camera has ceased to work. (In the applications the camera is working), it writes an error. In safe mode, the camera also does not work. Initially, the phone was updated via Wi-Fi, after the error made an update via a computer (the application from. Sony) did not help. At the factory settings, the application was reset without application upgrade.
Hi @Olesya52,
Sorry I'm unable to read the language in the error message, would you be able to translate that for me so I can help out
Let me know.
Hi everyone
after last updating the camera does not work I attached the application camera I tried to restore all factory data is other but in fact
Ciao a tutti
Il messaggio di errore è il seguente:
L'app fotocamera si è interrotta
x chiudi l'applicazione
Io ho provato se le seguenti soluzioni:
1) in modalita provvisoria
2) riparazione software da pc
3) ripristino dati di fabbrica
ma nulla di fatto l'app della fotocamera non risponde inoltre dal menu a tendina e scoparsa l'icona della torcia.
Mi chiedevo se era possibile disistallare l'applicazione fotocamera e reinstallarla visto che un app predefinita della sony perchè credo e spero che il malfunzionamento sia dovuto ad un bug dell'ultimo aggiornamento eseguito in quando la fotocamera ha smesso di funzionare dopo quest'ultimo.
Grazie a tutti
Translation via Google translate:
Hello to all
The error message is as follows:
The camera app has stopped
X close the application
I have tried the following solutions:
1) in safe mode
2) pc repair software
3) restoring factory data
But in fact the camera app does not even respond to the drop down menu and blot the torch icon.
I was wondering if it was possible to disconnect the camera application and reinstall it as a default sony app because I believe and hope the malfunction is due to a bug of the last update executed when the camera stopped working after that.
Thank you all
I used Google Translate to find the meaning of your message. Kindly post your future questions/feedbacks in English so we can assist you, this is an English based forum.
