hi, my phone z1 not working , suddenly shut down the when i turn it, give ( android is starting .... optimizing app .....) but until finish that optimize not open at all and do it again and again for more than 12 hours.
what should i do?
i was try turn it off from the red square and start but gave the same thing (optimize app)
i was try to press power switch and volum up but nothing change , try to connect to computer still not open.
help me what can i do ?
Hi @senorita-hana,
I'm sorry to hear this. I would recommend that you try and perform a software repair using Xperia Companion.
If you are unable to perform a software repair or if the phone is still behaving the same way after you completed one, I recommend that you get in contact with your Local support team for assistance with having your device sent in to an authorized service center for repair.
Let me know how it goes.
