Notification bar
Blueblack
Notification bar
Just wanna relay about these issues after nougat after. The notification bar of my unit the icons was gets doubled. See attached photos. Please help me to fix it. Thank you.Home screen notification bar icons gets doubledHome screen notification bar icons gets doubled
Menu notification bar view okayMenu notification bar view okay
2 REPLIES 2
Jonas
Master
Hi @Blueblack, welcome to our community! Slightly_smiling_Face
From looking at your pictures it looks like you have placed a screenshot as background on your phone. Could you try and change the background on your home screen and see if that helps?
You can change the background if you go to Settings > Wallpaper > Album (or if you rather want to use an Xperia wallpaper/Live wallpaper. If you choose Album, find the picture you want as background > tap on it > Home screen.
Let me know if that helps! Slightly_smiling_Face
ytheekshana
looks like a screenshot to me too
