Suddenly, this morning my Xperia Z5 (E6653) has tarted to behave abnoirmally:
- No notifications are displayed for ANY application even when they are enabled in the Settings.
- "Home" and "Recent Apps" screen buttons don't work. They are pushable and produce a tick when pressed. It's not a screen issue, but software. "Back/Return" Button works fine.
Tried reset but not results. No Software updates have been made since last week, no Apps installed or removed in the last few days.
Haven't tried a factory reset yet (dont' really want to).
I'm running Android 6.0, Build Number 32.1.A.1.163, with security patch level from 1-Feb-2016.
Any idea?
Thanks in advance!
After back up, The Repair Phone option in PC COmpanion has fixed all isues and set the phone to factory settings.
Issues fixed.
Update:
For the Notificatiosn issues I have found a similar thread in the forum, according to which I should wait for an apps update from 3rd party developers FOR EACH APPLICATION!!!! Ok, fine.
Strange enough, I have been using Marshmellow since several weeks ago and notification stopped working just this morning, not system update was done recently....
For the screen buttons being unresponsibe I'm tryingnow wot the repair Option in PC Companion, as suggested on another thread...
Will update with results...
Im still having this issue with my xperia z5 premium and ive done 2 system software repairs. completely wiping my phone and starting again and it still hasnt fixed the issue for me. also the recent apps button is unresponsive. Phone has manufacturer warranty until august
