Performance really disapointing
hajmyyy
 Hello guys I just want to share with you what I tried. I downloaded Antutu Benchmark and I started the test in normal condition on my table and of course the Z3+ was really overheating during the test. And the result was 68221 points then I cooled the device and put it in the freezer and started the test. It couldnt heat up so much so the result was optimal for Z3+ specification 86612 points. I think it's a bit shame and I would not recommend this device for my friend:( I got it for 1 year already and if I am using a lot apps together it heats up and starts lagging. I had SX Z3 compact before this and it had WAY better performance Slightly_frowning_Face
2 REPLIES 2
Uliwooly
@hajmyyy
why would you place ANY electronic in the fridge/freezer, you could if you want to damage them and/or crack the screen, but based on your previous post
/t5/Xperia-Z3/Power-button-is-stucked/m-p/1217380
it doesn't seemed that you take good care of your device, what you should do, is repair the phone with XC do NOT install any app nor update any preloaded app, install the benchmark and run it.
CzSama
It's about time that sony removes the thermal throttling really
