personal ring tones
Poohbear72
personal ring tones
in really step by step instructions, can anyone please tell me how i download a song onto my new phone and then add it as my ringtone?  thanks
christopherjz
Download the song to your phone via a website or with your computer. Then go to settings > sound > phone ringtone. Then complete action using file commander. Then navigate to downloads folder (if you saved the song from the Web) or wherever you saved the song with your PC. Done
4 REPLIES 4
christopherjz
Alexander1
Champion
You can also do as follows: Go to settings > sound > phone ringtone > (sound picker) > press the note icon in the upper right corner. > selecr the ringtone you have downloaded.
You can also go through the Walkman player. Open the Walkman player > go to library > songs > press and hold on the song > use as ringtone.
Poohbear72
Thank you
hedrox87
Contributor
Is it just me or own mp3 or acc ringtones are less loud than preinstalled by sony? I also have that feeling that walkman app is louder than ringtone when it comes to the same song, wasn't that tottaly otherwise prewiously in xperia series?
