My mobile displays constantly the window turn off / reset specially when I press any button: power, turn up or down. I can't turn it off, only reset even pressing power + turn up volume. It's so annoying. Any help? Thanks in advance
Hi
One time reset your phone to the factory mode.
Note: You will loose your data and accounts.
Aftet that if again you get this problem
call your local support http://support.sonymobile.com/global-en/contactUs/
Maybe your phone has software problem or hardware like buttons problem.
Good luck
