- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Highlight
Problem with the load is not seen by the update or by the carriage pin
Hola a todos, mi celular z5 e6633 no carga en modo normal, solo en modo flash que lo hago con volumen más y poder, y ahí prende un Led azul y carga, pero lo quiero poner en la pc para reparar el sistema operativo y la pc no me lo reconoce de echo lo pobre con 3 pc y varios cables entre ellos el original no se que hacer si hay otra solución o cambiar el pin de carga, desde ya muchas gracias y feliz año nuevo
Hello everyone, my cell phone z5 e6633 does not charge in normal mode, only in flash mode that I do with more volume and power, and there it turns on a blue Led and charge, but I want to put it on the pc to repair the operating system and the pc does not recognize me in fact the poor with 3 pc and several cables between them the original do not know what to do if there is another solution or change the charging pin, thank you very much and happy new year - GT
