problem with the sim
Sento
The problem is that the phone stopped detecting the sim suddenly Vovi her out and replaced and it worked but it has happened again and no longer detected at all ... the card was cut at the store because it was not microsim format could be this the cause? can serve the red button next to the place where you put the sim?. Thank you.
Sento
The matter is clarified, thanks,
5 REPLIES 5
Archanos
Contributor
Could be too old SIM standard, too slow chip, not a 3G SIM at all, card gets overloaded or simply was damaged in the process of cutting.
The size of the SIM is not always about only the size. There are different SIM standards, old ones are not always compatible with modern devices.
You should get new, Micro SIM card to avoid damage to the card and/or to the phone.
Sento
Thanks for the reply, I suspect something ..... I would like to know something about the use of the red button if anyone knows how and when to use
Uliwooly
If you want to reset your phone you will press and hold that button
http://www.xperiaguide.com/2013/09/12/xperia-z1-comes-with-a-physical-hard-reset-button/
Sento
Uliwooly
Anytime
