Hola tengo un Z5 , y no me funciona bien el wifi no se si es problema del celular o delu router , estando conectado al wifi no navega, entra a aplicaciones del facebook , instagram pero no actualiza las ultimas noticias , no podes ver fotos no podes hacer nada por que simplemente no carga y en el whatsapp no podes ni deacargar fotos, pero lo mas raro es que tengo un iphone 5 conectado a la misma red wifi y funciona sin problema navega ,entra en aplicaciones puedo postear cosas y demas, que le podria pasar a mi sony o al wifi
Hello I have a Z5, and I do not work well the wifi I do not know if it is a problem of the cell phone or delu router, being connected to the wifi does not navigate, enter to facebook applications, instagram but does not update the latest news, you can not see photos you can not do nothing because it just does not load and in whatsapp you can not even download photos, but the rarest thing is that I have an iphone 5 connected to the same network and wifi works without problem navigate, enter in applications can post things and others, you could I switch to my sony or wifi
GT
