Screen doesnt Rock alone
Ostini
Hello Friends,
Recently I have noticed that when the battery is in the range of 30% to15% power, the screen does not sleep/lock by itself. Before it reaches 30 or after lower than 15% it normalizes.
IF I dont press the lock button, it stays lit forever.
Did anyone experienced something similar?
Thanks
Uliwooly
That seems to be an app creating this issue, repair your phone with SUS or PCC
Update Service (SUS)
PC Companion (PCC)
Bridge (for Mac)
http://talk.sonymobile.com/thread/36355
6 REPLIES 6
Uliwooly
PC Companion (PCC)
Bridge (for Mac)
santam1
Contributor
I think your lock screen setting has been changed and did you turned on your " Low Battery Mode" in power mangement ?
please check the followings..
Go to settings > security > check the screen lock and make sure it is not set to None choose your desired security option.
check with Display > Sleep and choose your desired screen time out time
check those and see if it resolves and keep me posted..! :smileysmileythumbsup:
Tags (1)
Ostini
Thanks uliwooly
will try the SUS and post later if solved.
This morning, with the battery fully charged, the problem remain.
So musn't be a batt level issue indeed.
Ostini
Santam, tks for the reply.
I did check these settings before and they are all ok.
So musn't be a batt level issue.
The first time it happened I rebooted the phone and problem disappeared.
But returned later.
Uliwooly
You might want to stop by a Sony repair center
Ostini
Friends,
Just for the record it was apps running in background... Closing them using the button on the right of Home button solved the issue
Tks
