Since yesterday, my SD card is no longer in the slot. Therefore, the cover jumps up or does not stop at all. If I the card with the lid reindrücke and with adhesive tape fix, is again everything ok. But is not a permanent solution. What can I do?? Who knows the problem
since this is a harfdware problem. I suggest you to take your device to your local service center. Local support
for the mean time. do not use your phone near wet environment
