Por favor me pueden decir que formato de tarjeta microsd admite el Sony Xperia z3
Please can you tell me which microsd card format supports the Sony Xperia z3
Translated with Google Translate.
They said this:
"Hampus
Master
2014-10-06 02:05 PM - edited 2014-10-06 02:07 PM
Message 2 of 7
Re: Memorycard for Xperia Z3
Xperia Z3 supports a microSD-card(SDXC supported) up to 128 GB. I would recommend class 10 if you want to record videos in full 1080p. And if you are going to record in 4K, I suggest that you look for a SD-card with speed class UHS.
sony_sign_logo.png - Official Sony Xperia Support Staff
If you're new to our forums make sure that you have read our Discussion guidelines.
If you want to get in touch with the local support team for your country please visit our contact page."
You can check in this page:
