Serious issue on my ZL! Phone not starting up after .253 update + LED notification continuously showing Red!!!
Mindfreak_17
Tried even SUS & PCC as suggested but nothing works! My beautiful phone is just lying there....
22 REPLIES 22
Uliwooly
take your phone to a Sony repair center
Mindfreak_17
I tried your way again and charged it for an hour and tried to turn it on... The LED blinked and then went off.. the phone didnt turn on..:smileyplain:
Uliwooly
take your phone to a sony repair center.
Mindfreak_17
I will but just wanted to know if theres any other trick / tweak up your sleeve which i should try Slightly_smiling_Face
Uliwooly
there aren't any other suggestions I can think, sorry.
Mindfreak_17
Hey uliwooly, thanks for the advice, went to the Sony Centre yesterday and they declared the battery as dead and confirmed that they would need to replace the phone.
A l'il dissapointed the way it turned out but hey i'll get my new ZL soon (expected in the next 7 days) Slightly_smiling_Face
Till then i'll use my Xperia Arc and manage... I'm an Xperian for life! Winking_Face
Mindfreak_17
Uliwooly hellllppppppppppppp! My NEW, REPLACEMENT phones not turning on Slightly_frowning_Face I left it on charge for  a couple of hours in the morning with a little over 20 % battery & it was fine but now its completely DEAD! No LED light, not turning on, NOTHING!!
PLS PLS PLS HELP!!!!
Uliwooly
have you try the basic
connect the phone to the wall charger > press and hold power & volume up for 10 seconds > let it charger for 1 hour > try to turn it on again
Mindfreak_17
Yes Mr. Super User... i'm trying that now... Shall update after an hour
Mindfreak_17
DIDNT WORK!!! :smileysad::smileysad::smileysad: HELPPPPPP
