should I upgrade to lollipop
djb1
Hi All,
           I'm seeking the general opinion of whether i should attempt the possibly mammoth task of upgrading to lollipop. My dilema is that i'm almost 70yrs old and the last thing i want to be faced with is a non functioning z1c. You guys have no doubt been through the process  and hopefully will advise accordingly. thanks in anticipation of a reply
Uliwooly
@djb1
mixed opinions, keep in ind that this is a support forum, most users will come here when they have issues, in other words, opinions will be a bit biased, but you can read them here
http://talk.sonymobile.com/t5/Xperia-Z1-Compact/bd-p/Xperia_Z1_Compact
3 REPLIES 3
Uliwooly
@djb1
djb1
Thanks for your reply. Think I really need to seek practical help from a 3rd party.
Uliwooly
@djb1
Anytime, let us know if you have any more questions
