Check the camera lens, is there anything blocking it or partially blocking it?
Are there any scratches on the lens?
Do you experience the same with other camera apps?
Ok, so there's a new back cover that might be creating this issue, make sense, I've seen that before. just to double check, when you remove the back cover it work just fine?
Ok, keep us updated
