I am looking to buy one microSD card for my Xperia Z2 Phone (6503). My question is: how fast it can write data to an SD card. For what I know, these speeds depend of SD Card controller. If I will know approximative numbers I can acquire adequate microSD card. Right now I am trying to decide between: SanDisk SDSDQX-064G-U46A Extreme Plus 64 GB - 80 MB/s SanDisk SDSDQUA-128G-G46A Ultra 128 GB - 30MB/s Writing speeds for these microSD Cards are half of indicated reed sped numbers. I like 128 GB capacity of Ultra Card, but will not hesitate to buy faster 64 GB Extreme Plus Card.
Indeed,consider at least class 10 microSDHC(SDXC > 32 GB) if you want to enjoy 4K.4K bitrate is somewhere around 54 Mb/s~7 MB/s as azzido said.
Check out the forums re SD cards being "fried" by the phone (it happened to my 64gb San Disc) before you shell out your hard earned for an expensive one.
