Speed test on home screen
mickie
Since yesterday the speed test icon on my home screen won't load the app. Other apps on home screen work fine. Not sure what's going on.
Uliwooly
As long as you download apps from the play store, and you don't visit dubious websites you should be OK. A taskiller will stop/kill running apps in the background, this sound like a good idea but it isn't as this apps will reopen soon after, thus draining more battery than letting them run, also it can create connectivity issues
5 REPLIES 5
Uliwooly
uninstall the app > reinstall the app
Do you have any taskillers or antivirus?
mickie
Thanks for that. It's fine now. I have norton mobile.
Uliwooly
You don't quite need an antivirus or taskillers or task managers, uninstall them > restart your phone > check again
mickie
I'm a bit confused. I'm new to android having had an iPhone for years. I thought I would need a virus checker ?? Also, what is an app killer?
Uliwooly
