HI,my Z3 Dual is stoppted suddenly.I connected it to cheger for half hour but it does'nt power on!
Nothing I can do - you could send your phone away back to country it was bought in or take a chance on either a DIY or store that repairs phones and or replaces batteries
@kanchuka That wouldn't work as the member has no power to boot the phone - Even Flashmode requires power when manual flashing
You may need to perform a software repair using PC Companion.The process will erase all internal memory.You might need to charge your device for about 1-2 hours before so the device has at least 60% battery.
Make sure the device is not connected to computer or laptop and turned off (sometimes you have to press power button and volume up until the device vibrates 3 times or on some devices you have to press the small button near the SIM tray or on the back of the device).
Open PC companion->support zone->phone/tablet software update->repair my phone/tablet blue highlighted.Follow the steps given,do not connect your phone until prompted to press volume down while plugging USB cable. If PC companion does not start the repair process, you might need to run it in compatibility mode with Windows 7 (in some cases XP).
Once again have encountered the irritating sudden death I have tried...
1. Wall charging for more than 3 hours after pressing volume up + power button
2. Power + Volume up
3. Yellow button in micro SD card slot
This happened with 57% battery
Cannot connect phone to the computer and there is NO charging LED basically no sign of life... unacceptable for an expensive phone so far regretting the purchase.
