hola tengo un problema la barra de ajuste de brillo no sirve que me recomiendan hacer ayuda por favor
hello i have a problem the brightness adjustment bar does not serve that they recommend me to do help please
Translated with Google Translate.
Hi @wubboger96,
This is an international community and I have translated your latest post to English using Google Translate, please keep all future post in English.
I'm sorry to hear this. I recommend that you turn of adaptive brightness, to do so go to: Settings > Display >Adaptive brightness > Off. If you are still experiencing the same behavior I recommend that you restart your device safe mode to see if this behavior is caused by one of your downloaded apps.
Let me know how it goes.
sigue con ese problema ya hice todo lo que me recomendaste que hago 😞
keep up with that problem I already did everything you recommended that I do 😞
GT
Then I recommend that you move forward and perform a software repair using PC Companion.
Keep me posted how it goes.
