Hi There
My Z1 cannot record video. It says error , camera is not avaiable .. The camera works fine taking photos.. Any suggestions ??
Thanks for the help . I erased some apps who was recording audio, and suddently it worked fine
@sankem wrote:
У меня такая же проблема, до этого все было хорошо, а потом просто перестала работать. Причем, фото тоже делает, а на видеозапись выдает ошибку.
I have the same problem, before all was well, and then just stopped working. Moreover, the photo also makes a video on an error.
Try to repair via sony update service:
http://www.sonymobile.com/gb/tools/update-service/
If not helping,visit a sony service:
http://www.sonymobile.com/global-en/support/contact-us/
I would suggest that you first of all try to boot your phone into safe mode to see if the problem may be related to any 3rd party app that you have installed in your phone:
http://talk.sonymobile.com/t5/FAQ/How-to-boot-your-phone-into-safe-mode/m-p/348008#U348008
Great.
May I ask which apps? There are some Id be really reluctant to delete, like facebook messenger 😕
My video is really up the spout, either doesnt record or does but then wont stop.
Currently it stopped by plunging the whole phone into darkness and I cant switch it back on
I went in and force stopped it and deleted all its data etc, and it worked- but i cant do that every time I want to make a vid
