Too much red in display
jeroendh
I have my Z5 now for 1 day, and I see a big difference in the screen from my Z1 and the Z5.
There is too much red on the Z5. On pictures faces are red instead of normal skin tone.
I have disabled the X-reallity mode on both phones.
Someone els has this problem?
11 REPLIES 11
Thommo
You can manually adjust the colours and tone down red colours
jeroendh
The whitebalance settings you can only ADD red/green or blue. It's not possible to lower one of the colors.
Thommo
Are your colours already at level 0 Zero? if they are then I have no other options for you
jeroendh
Yes all the colors have level zero now.
ratacit
Contributor
They compensate / compliment. Play with the sliders. My Z3 is also out of balance. My current settings are R26 G30 B129. Sad to hear that Z5 also have the color cast. For a device advertised for its camera capabilities is not good to have un-accurate colors. How's the devise otherwise? The Z5C users report really serious issues with camera and display and overheating.
MartyvH
My Z5 Compact had too much red, so I turned blue and green up to 160 and problem solved. Though 160 seems like a very high value to compensate for it. The screen was badly manufactured, I think.
aLERNO
I have the same problem, whatever I try, red is way too saturated, images are of bad quality.
Did you find any solution?
aLERNO
In my case changing green and blue to a high level doesn't change anything.  Red is still way too intense, saturated..
Ray111984
Same problem
Set green to 70 in display settings and you're good.
