I have a Z1s running 5.0.2 and I'm not a big texter. I'm using the stock apps for texting and contacts. I was trying to send a text to someone I had never texted before. I brought up their contact page and pressed the little text icon and I got a texting screen except that it was covered by a menu that had options like 'add video', 'add picture' and a bunch of others that prevented me from actually being able to text. The options did nothing and the back arrow also did nothing, so I was prevented from composing and sending a text. I sent the text I needed to from my desktop using mighty text. When I received a reply, I was prevented from reading it by the same menu which still did nothing. That was yesterday. Today, the menu was gone and I could read the return text. For a while though, I was prevented from reading any other text I had received. I would press on one and the first one I looked at came up instead. Then that went away after a while and things seemed to have returned to 'normal'.
I really don't understand what is going on with my phone. I like the phone and I love the battery life, but this bit of weirdness and the fact that some apps that worked just fine on my N4, don't seem to work at all on the Z1s. I have an app named Move that counts your steps during your day. It worked just fine on my N4, but on the Z1s it's only counting maybe 1-3% of my steps. It says I walked 89 steps yesterday and that is absurd. I assume that the app uses the accellerometer to do its work. I have another app that uses the gps for tracking and it's not registering anything even though the gps seems to be functioning. And the phone doesn't have as good a connection during calls as my N4. I get a lot of static and breaking up during calls that I never got on my N4. 99% of my calls are made and received at my home, so that is what I'm comparing.
Anyone have any clues as to what is going on here? The update to lollipop was done through the pc connection. Any additional updates have been done OTA. I haven't rebooted in a while and I think I'll try that first.
TIA
LT
I'm sorry to hear about your issues, take a screenshot of the issue and post it here or on box or dropbox and post the links here, so we can help you
as for the other apps not working that has to be addressed by the app developer not Sony, I do recommend you Google Fit and also LifeLog.
How old is the SIM card? is it a micro SIM card or did you trimmed it?
The texting problem has gone away for a while, so I can't take a screen shot. I loaded the suggested messaging and google fit. I don't like changing apps if what I had worked under lollipop on my N4 and now that I have the Z1s also running lollipop they don't. It seems to me that Sony must have something to do with this problem. Either the hardware or the software (os) is significantly different (inferior). The gps tracking app I'm using is called Bubbler. I tested it today and it only registered my location a handful of times instead of the every 5 or 10 minutes like it's supposed to. To me this indicates that the gps is not functioning properly.
The phone and the sim card are about a month old and it came as a micro sim.
I don't mean to be a whiner, I'm just confused and disappointed that things are not functioning as I expected. And on top of all that, the call quality is less than stellar.
Sorry
LT
The texting problem has not re-occured, but then I don't text much. I switched to Fit and it works fine.
The call quality is still iffy. Most of the time it's fine, but occasionally in the middle of a call, I'll start getting a lot of static.
I really don't understand, but I guess I'm sticking with the Z1s until it does something else inexplicable.
Thanks
LT
My sony erricssion crash monitor stopped few days ago so icant open my some apps like facebook .
