Wi-Fi and Bluetooth do not work.
maxtwodoubleoon
Translation via Google Translate:
The Wi-Fi function and the Bluetooth function do not work. Restarting the mobile phone does not solve the problem. Could it still be due to the software, or is an antenna broken? Mobile phone has not fallen down lately, nor have other brute force acted on it.
Die W-Lan Funktion und die Bluetooth Funktion funktionieren nicht. Jedwedes Neustarten des Mobiltelefons behebt das Problem nicht. Könnte es dennoch an der Software liegen, oder ist eine Antenne Kaputt? Handy ist in letzter Zeit weder runtergefallen, noch haben andere rohe Gewalten auf es eingewirkt.
6 REPLIES 6
profile.country.US.title
Qatrium
@maxtwodoubleoone
I used Google Translate to find the meaning of your message. Kindly post your future questions/feedbacks in English so we can assist you, this is an English based forum.
Try resetting your network settings (this will also erase all your saved Wi-Fi connections, Data allowance, APNs, and more. So you'll need to set those again after reset):
Go to Settings -> More -> Network settings reset -> RESET SETTINGS.
av-qp
have reset network settings and still cannot connect to wi-fi
Alrounder
Bluetooth as well as WLAN does not work anymore
Bluetooth sowie WLAN funktioniert nicht mehr
LG
Alrounder
Upsetcustomer
have you been able to fix this yet, i think we may be having the same problem
Scott2911
I'm also having the same problem?? Any suggestions
roma2746
Have the same prolem.
was a solution found?
