WiFi Issue
cobbler
WiFi Issue
Every so often while using my home wifi on 5g I begin to have a connection problem when the wifi icon goes from white to non white then back to white again indicating the connection is going on and off, I have to switch the phone off completely and this sorts the issue.
Any idea what causes this?
Tags (2)
9 REPLIES 9
Uliwooly
@cobbler
Could you test the phone in safe mode for several hours and see if you experience the same issue?
cobbler
@uliwooly wrote:
@cobbler
I could but I never can tell when it will happen again.
Uliwooly
@cobbler
The only thing I can suggest is to repair the phone with XC or keep an eye on which apps are running/open when that happen
cobbler
@uliwooly wrote:
@cobbler
Does using repair on XC check the system files only for corruption and reinstall any if necessary?
Uliwooly
@cobbler
if will only give you an option to reinstall the latest update
cobbler
Trouble is that when trying the safe mode solution you have to restart the phone which by doing so normally would fix the issue anyway till the next time.
So I wouldn't know which third party app it could be.
cobbler
Am I correct in thinking that the software repair option using the Xperia Companion I would be required to install all my apps again from playstore?
profile.country.US.title
Qatrium
@cobbler
Yes, this will do a clean installation of the latest firmware and will also wipe your internal memory. Don't forget to backup using Xperia Companion, but preferably without adding apps or settings to the backup.
cobbler
@Quester wrote:
@cobbler
@Quester
Thank you.
