My Sony Xperia z 5 premium
After last update, the Bluetooth device in always keep running??
I turned off,, after minutes it's Wil turned on again? Without any reason??
Settings > bluetooth > turn it off > Scanning settings > Wi-Fi scanning > disable it
I did everything, that's not solution
I don't know what you mean by "everything" if you don't give us more info, we can't help you.
Boot on >>> safe mode for many hours, check if you experience the same issue.
Note:
@Sanbabilaq8 wrote:I did everything, that's not solution
That's not a proper reply.
