Xperia ZL 4.2.2: Walkman controls and lock screen conflict
ylapas
Anyone is facing the problem of blinkink album art and Walkman controls while playing music on lock screen widgets? I looks as app conflict here because Walkman is trying to go on top of of clock widget and is rapidly blinking. Screenshot does not capture this, yet you can see to screens on top of each other and Walkman is the blinking one and is not the "winner" of lock screens battle Smiling_Face_with_open_mouth_&_closed_EyesScreenshot_2013-06-27-16-39-00.jpg
servarus
Guys, I think I found the culprit.
Do you have Smart Key installed? I was cleaning up some apps, and after I uninstalled Smart Key, the lock screen worked properly.
Do give it a try and see how it goes.
24 REPLIES 24
GeoffH
Enthusiast
looks like a bug - whats the icon in the notification bar on the left ?  circle with dot in middle
ylapas
If you are asking about "a" circle - avast! Mobile Security icon. I am interested to hear am I the only one with this or is there more users with the same Walkman and lock screen widgets behaviour.
GeoffH
Enthusiast
you will read many many threads here with advice to remove such software and any other utilities you have installed - they are not needed and are known to cause issue with Android OS
merulez88
Hey guys.
Seem my Xz also having the same issue.
Walkman will clashing with the lock screen pattern on my phone.
its annoying..:smileyangry:
Its the anyway to solve it?
also the are some app will keep crashing by using JB 4.2.2, looks like to remove to crashing app from my phone..:smileysad:
eutactic
It works in my xperia z before.
Get the same issue today.
crandrix
@aylapas I got the same issue after the update. The screen flickers and the widget goes away. Just in case, I don't have any antivirus, battery saver or something like that.
ylapas
At least now I know it may be a bug, not my local Xperia ZL problem. Seems we will have to wait for some comments or update from Sony now.
crandrix
I forgot to add, what I have is the XZ. It's same software so I guess we will have the same issues.
servarus
I am also having this same problem. The screen flickers non-stop, although I can unlock my screen normally. Not sure why.
Plus the sensitivity of the normal lockscreen is very high. I want to slide to access the camera, but it went to another lockscreen page. Same thing happens if I want to slide to access to media control.
